I have a bunch of SVG images that I would like to include in some notes, but they don't render in the display pane. Is there a setting or plugin I can use to display them?
SVG images display by default for me in the markdown viewer
Or if you're referring to displaying them in the markdown editor view, you would need to either use the rich markdown plugin (and enable its setting to display images) or enable Markdown editor: Render images under Tools | Options | Note
If I disable ALL plugins, the image shows in the display pane. So I enabled them one at a time (painful). The culprit is FREEHAND DRAWING, which I can live without.
