I’m a new user, migrating from Evernote. I really liked the feature of drag and drop text to re-organise and re-arrange text lines and sentences in Evernote. On the left at the start of the text, there are four dots that when you click and hold, can re-arrange it above or below other text. Does such a function exist in Joplin. If so, what is it called? If not I would love this function added.
There are swap line up / down functiona available in the menu, to move a single line, if using the markdown editor. On the mobile app, you can also enable these options in the editor toolbar
There is a cog on the very right of the bottom toolbar when editing a note (if to don’t see it, try to scroll the toolbar horizontally). In that settings menu you can enable the swap line up and swap line down options
