I don't like markdown.I like WYSIWYG(rich text editor).
But there is a problem:When I press enter,system create two newline.
The distance between line and line is to too far.
I heard to use shift+enter instead of enter can create only one newline.
But I think use shift+enter to instead of enter is too trouble.
Is it able to add a setting in settings:"use enter instead of shift + enter in the WYSIWYG(rich text editor)"?
This is very useful for WYSIWYG(rich text editor) users.
I wish I can use enter to create one new line in WYSIWYG(rich text editor) but not shift+enter to create one new line in WYSIWYG(rich text editor).Use shift + enter to instead of enter is very trouble.
Can you put this into settings?Then I can use enter to create one new line in WYSIWYG(rich text editor) but not use shift+enter to create one new line.
Thanks.
system:windows7 x64
Joplin 2.7.15 (prod, win32)
sync version: 3
config version: 41
support encrypt: 是
edit: 8352e23
