Introducing Padia Rashesh
I am currently pursuing BTech CSE from India. Currently learning nodejs :slight_smile: I installed joplin recently and I liked it. Looking forward to solve some issues on github
Github id - Rash419
I have built hello world plugin but while installing I cannot find Configuration option in joplin as mentioned in plugins.md
you can find the configuration option in Tools>options>Plugins>Show Advanced settings and in the development plugins write the path to the folder containing your plugin.
Hope this helps :slightly_smiling_face:
thanks :slight_smile: but when I do changes in plugin it doesnot show its affect in joplin app . I tried restarting joplin but still it is not getting updated :frowning:
try running npm run dist in the root directory of the plugin after making any changes to the plugin code and it should refresh
oh yeah thanks :slight_smile:
