Incorrect attachments when importing from Evernote
  • Joplin 1.0.227 (prod, darwin)
  • macOS Catalina 10.15.5
I recently imported about 2200 notes from Evernote over to Joplin using the Mac Client.
I noticed that if a note has multiple attachments, the order of the attachments is wrong. For example:
There are 4 attachments in the following order in Evernote:
  • 1.pdf
  • 2.pdf
  • 3.pdf
  • 4.pdf
When imported in Joplin, the order becomes the following:
  • 2.pdf (opens 1.pdf)
  • 4.pdf (opens 2.pdf)
  • 3.pdf (opens 4.pdf)
  • 1.pdf (opens 3.pdf)
There can be various permutations and combinations of the above - basically it never opens the correct attachment.
Any help would be appreciated! Thanks.
Could you post an ENEX file that shows the issue?
Sure. Here it is: Testing.enex (60.8 KB)
Evernote Screenshot
Joplin Imported Screenshot
Note
If you click on test2.pdf in the Joplin version, it’s actually test1.pdf
