Importing PDFs problem
Hi All,
O/S - Win10, Joplin V2.8.8, Web Clipper V2.8.1.
If I open a downloaded PDF using Chrome, then try to clip it as html into a new note, all I'm getting is a link to the PDF. I'd like to be able to have the PDF readable in Joplin as opposed to it opening in Acrobat.
I've had a search through the forum but can't get my head round the answers. Is there a simple way of doing this? Please!!!
If you toggle the editor to markdown mode (top right corner) and if needed toggle the editor layout, you should be able to see the pdf in the inline viewer.
Thanks, it didn't seem to work for me, but I've managed to find a work-around.
