Icon not showing on macOS toolbar (top right corner)
macOS
Joplin 3.4.12 (prod, darwin)
Device: darwin, Apple M3 Pro
Client ID: be626b261fe74cb3b53a9ed18aff4a1b
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
Backup: 1.4.3
Freehand Drawing: 3.1.0
Tagging: 1.0.3
WebDAV
Rich Text Editor
Hi all,
The Joplin icon does snot show up in the toolbar, top left corner, on my macOS screen. Basically where the GDrive, Wifi etc.. icons are.
It does appear on another mac (old OS) I have, but not on this one.
Any feeback much appreciated.
Thanks,
Ben
It seems that I had too many icons up there. Went to System settings, then Control Center and unchecked many of the icons. The Joplin on appeared. I still find it odd though.
