How to stop joplin from scrolling up when i switch to another note?
Joplin 3.5.13 (prod, win32)
Device: win32, AMD Ryzen 7 7800X3D 8-Core Processor
Client ID: f8bd38929cbc4322a3852a59daae2c9c
Profile Version: 49
Alternative instance ID: -
Revision: 0c1511f
Backup: 1.5.1
Create and go to tags and @notebooks: 1.3.7
Extra Markdown editor settings: 1.11.0
Freehand Drawing: 4.2.0
Journal: 2.0.0
macOS theme: 1.5.20
Note Statistics: 1.0.4
Quick Links: 1.3.2
Rich Markdown: 0.17.1
Simple Image Resize: 1.5.16
OneDrive
Whenever i switch to another note, the scroll wheel just keeps scrolling up. have no clue why because im always at the bottom of the notes whenever i switch. any way to fix this? it gets really annoying when im trying to switch btwn two diff really long notes
Are you using the markdown or rich text editor? Also, try disabling all plugins and see if that helps
this might be because joplin scrolls to where your cursor was when you switch to a note, not where your last scroll position was
so if you're looking at a note and your cursor is on the 1st line, you scroll to the bottom of that note (but don't move the cursor), then switch to another note and then back, the default scroll position will be at the top (where the cursor is)
no ive clicked at the bottom to put my cursor there and it still scrolls up whenever i switch, and i do it for both notes. it doenst scroll all the way to the top though, but still scrolls up quite a bit.
ok it seems like it was a plugin lol, turned them off and it fixed, i dont know why that didnt cross my mind. thanks yall for the help tho :sob:
