I asked a similar question before. However, I couldn't get a reply. This bothered me with use and seemed a little inconvenient.
Thanks to the developers and other contributors, I see that there doesn't seem to be a good workaround for this issue at the moment, is that right?
Similar issues.
Yes, that is correct. There is currently no good workaround for the issue of the plugin panel not supporting adaptive sizing. This is a known issue that has been reported on the Joplin GitHub repository, but there is no timeline for when it will be fixed.
In the meantime, there are a few things you can do to make the plugin panel more usable on smaller screens:
Resize the plugin panel manually. You can do this by clicking and dragging on the border between the plugin panel and the editor panel.
Use a smaller font size in the plugin panel. This can be done by changing the font size in the plugin's settings.
Use a plugin that doesn't have a panel. There are a number of plugins that don't have a panel, or that have a panel that can be disabled.
I understand that this is not ideal, and I hope that the developers will fix this issue soon.
