How to de-activate 'check spelling' in WYSIWYG
Hi. Mine is a simple question on how to use Joplin. Here are mi data:
Joplin 2.5.12 (prod, win32)
Profile Version: 39
Revision: 884b86f
Can anybody please tell me where to find an answer to these two questions about the WYSIWYG editor?
--How to de-activate 'check spelling'? I don't need it and the red underlinings are a bother when I'm not writing in English.
--How to NOT to include an extra space after paragraph.
Thanks in advance.
Rosanna
The answer to the first is in the top right, the little globe icon:
The answer to the second is you need to press shift + enter
I made a post before which you might like to look at to explain why it does it - Rich Text Editor Press "Enter" get two carriage returns - #3 by Daeraxa
Thank you so much, Daeraxa!
