How to best use with xournal++/show pdf'S
Joplin 2.13.15 (prod, win32)
Client-ID: 8116c7aff80141ec8efab7711c1edf6f
Sync-Version: 3
Profil-Version: 44
Revision: 7d2c1c0
Freehand Drawing: 2.7.1
Rich Markdown: 0.13.3
How do I best use joplin with xournal++? I want to replace OneNote because its unreliable. I really like xournal++ as a handwriting app (the new js draw plugin is ok, but not suitable for my needs). But I want to show the documents from x++ in a journal notebook, preferrably the .xopp (but that probably won't work for some time) and alternatively the exported pdf files with automated updates. As for now I only get the pdf rendered in markdown mode and with a (bit ugly imo) scrollable frame. And I would appreciate if you'd have a good first step guide to read through? (like these plugins are popular and useful for this and that) All the information I could find is 2 to 4 yrs old and seems quite outdated. Thanks for your help :slight_smile:
