Hotkey / Command for Toggling Between Editors
Hot Key / Command for toggling between editors (Markdown and Rich text). Currently there is no behavior implemented to accomplish this. Below is our proposed Refactor to make this change.
  • Implement new Toggle Command
  • Add as a Command
  • Import to Command Service
Now Toggle Behavior should be added to "ctrl + shift + e"
Please let me knows Thoughts/Feedback
Good idea this shortcut...
By my side, I would prefer a Function key, it's really more easier to use ! For example : [F5]
+1, this would be a nice feature
regarding the specific hotkey, if this was implemented as a hotkey, presumably you would be able to change the key to whatever you wanted in the hotkey settings.
