Hello. While typing in the note text editor of Joplin’s AppImage on Linux I observe quite high CPU load… >50% on my admittedly not super fast laptop. Is this behavior expected?
Version tested: Joplin-1.0.106-x86_64.AppImage
Does it do it on all the notes or just some of them? Does it happen when the note is almost empty?
Hi Laurent, thanks for the quick response.
The behavior does not seem to be related to note length and can be observed on all notes, even completely empty ones. On my machine I can reproduce it by simply creating a new note and entering text.
Here’s a short screencast that shows the described behavior: https://imgur.com/a/TtfO8yx
The window on the left shows the output of the top command.
