Hiding Passwords with Markdown
I love using markdown to organize stuff. The issue is, I store passwords and usernames in some of my notes but I hate having them in clear text in case people are looking over my shoulder. Some markdown websites/plugins have the use of !> to hide text until it’s hovered over with a mouse. Something like that would be great!
C10
You could add something like this to userstyle.css
.hidden {
  background: #000;
  font-color: #000;
  transition: background 0.5s ease;
.hidden:hover {
  background: none;
And then in your notes you could use it like:
Here is a large block of text with a hidden <span class="hidden">password</span> that is only revealed on hover.
I know it’s not ideal, but you can get this working today as opposed to waiting for someone to implement this as a feature.
P.S. I got most of this code from here
You can also use MD Comment syntax to hide text in the MD Preview.
MD/HTML comments work, but not when inside a MD table… which is unfortunate.
I guess i’ll just have to use some HTML and customize the CSS. Cause that seems like the only way to get it to work within a MD table
Thanks for the responses!
Yep, this works in an MD table with no CSS.
<!-- hidden text -->
Ohhhh that actually worked. Was this due to the update? MD seems updated as well on this new Joplin version. I could have incorrectly used the tags when I tried earlier (possible).
Thanks!
Hmm, maybe we could add a few markdown extensions like discourse does. IMO it shouldn’t be hard to add. @laurent has to decide, if he wants this in Joplin.
There are more pressing issues to tackle, but maybe we can keep this in the back of our heads…
e.g.:
[spoiler]This text will be blurred[/spoiler] click on it to make it readable
This text will be blurred click on it to make it readable
and
[details="Summary"]
This text will be hidden
[/details]
Summary
Hi @tessus! Are there any chances that this syntax will be added to Joplin?
I doubt it, unless someone creates 2 markdown-it plugins, which we then could add to Joplin.
I don't think there's even a Markdown syntax for this. Using square bracket tags is really bbcode and let's not go there :slight_smile:
I think Caleb's solution is the way to go. Just use Html, which is already supported and more portable than bbcode, along with userstyle.css
I’d like the syntax from this plugin: https://github.com/markdown-it/markdown-it-container (and another tool Pandoc uses something like that: https://pandoc.org/MANUAL.html#divs-and-spans)
But it also requires using custom userstyle.css
