I’m using Linux and i3-wm. When you right-click on the Joplin tray icon, the only options you have are “Open Joplin” and Exit. Is it possible to hide a third item like “Hide Joplin” to reduce it?
Thanks
You mean add a new item called Hide?
I'm not sure it is really necessary since you can just close the Joplin window or use the Hide menu item (Cmd+H in macOS) or Close Window (available on all desktop platforms).
Yes, that's it.
It's not necessary when you use a stacking window manager like on macOS, Windows or GNOME. But, i3-wm is tiling. In tiling WMs, you don't have the notion of standard reduction to taskbar.
Cheers
Ok, it’s not my decision, but in case @laurent is ok with such a change, here’s a PR:
Great!
Thanks for that!
