I try to make a black theme for my Joplin with userchrome.css running Joplin 1.0.179 under Linux.
But I run into the problem that some elements do have the same class: div. If I change the background color for div I can't see the elements in the editor view anymore.
How to make the viewer pane also black
how to make all the litle lines in-between black (they are all div)
how to make the little part in front of the checkbox black?
