C:\Users\user\Desktop\joplin>npm install
> root@ postinstall C:\Users\user\Desktop\joplin
> npm run bootstrap --no-ci && npm run build
> root@ bootstrap C:\Users\user\Desktop\joplin
> lerna bootstrap --no-ci
lerna notice cli v3.22.1
lerna info versioning independent
lerna info Bootstrapping 15 packages
lerna info Installing external dependencies
lerna ERR! npm install exited 1 in '@joplin/server'
lerna ERR! npm install stdout:
> sqlite3@4.1.0 install C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3
> node-pre-gyp install --fallback-to-build
Building the projects in this solution one at a time. To enable parallel build, please add the "/m"
switch.
C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\Common7\IDE\VC\VCTargets\Microsoft.Cpp.Platform.targets(67,5): error MSB8020: The build tools for v140 (Platform Toolset = 'v140') cannot be found. To build using the v140 build tools, please install v140 build tools. Alternatively, you may upgrade to the current Visual Studio tools by selecting the Project menu or right-click the solution, and then selecting "Retarget solution". [C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3\build\deps\action_before_build.vcxproj]
Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
lerna ERR! npm install stderr:
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.0/node-v83-win32-x64.tar.gz
node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.0 and node@14.16.0 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! build error
gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Windows_NT 10.0.10586
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "build" "--fallback-to-build" "--module=C:\\Users\\user\\Desktop\\joplin\\packages\\server\\node_modules\\sqlite3\\lib\\binding\\node-v83-win32-x64\\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\\Users\\user\\Desktop\\joplin\\packages\\server\\node_modules\\sqlite3\\lib\\binding\\node-v83-win32-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (C:\Users\user\Desktop\joplin\packages\server\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Windows_NT 10.0.10586
node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\user\\Desktop\\joplin\\packages\\server\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd C:\Users\user\Desktop\joplin\packages\server\node_modules\sqlite3
node-pre-gyp ERR! node -v v14.16.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules\chokidar\node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.2.1 (node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.2.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sqlite3@4.1.0 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sqlite3@4.1.0 install script.
npm ERR! C:\Users\user\AppData\Roaming\npm-cache\_logs\2021-03-11T20_45_06_895Z-debug.log
npm ERR! errno 1
npm ERR! root@ bootstrap: `lerna bootstrap --no-ci`
npm ERR!
npm ERR! Failed at the root@ bootstrap script.
npm ERR! C:\Users\user\AppData\Roaming\npm-cache\_logs\2021-03-11T20_45_06_983Z-debug.log
npm ERR! errno 1
npm ERR! root@ postinstall: `npm run bootstrap --no-ci && npm run build`
npm ERR!
npm ERR! Failed at the root@ postinstall script.
npm ERR! C:\Users\user\AppData\Roaming\npm-cache\_logs\2021-03-11T20_45_07_039Z-debug.log
Do you have Windows Build Tools installed?
YES I have already done .We can do it from anywhere or from root of joplin file?
Do what? Install build tools? The doc suggests installing it globally. Is that how you did it?
yes
What's the output if you execute this command?
which command?
And this too
C:\Users\user\Desktop>"C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\user\\Desktop\\joplin\\packages\\server\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
internal/modules/cjs/loader.js:883
throw err;
Error: Cannot find module 'C:\Users\user\Desktop\joplin\packages\server\node_modules\node-pre-gyp\bin\node-pre-gyp'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
at Function.Module._load (internal/modules/cjs/loader.js:725:27)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
at internal/main/run_main_module.js:17:47 {
code: 'MODULE_NOT_FOUND',
requireStack: []
Does this path exist? One it says it cannot find.
Ok, I think I have figured this out. Try installing windows build tools like this:
npm install --global windows-build-tools --vs2015
Then run npm ci from the root again.
