I am trying to setup the project in my local system and it's showing some errors.
Steps I followed after reading the documentation https://github.com/laurent22/joplin/blob/dev/BUILD.md
- first i opened powershell using administrative rights and installed windows-build-tools using 'npm install -g windows-build-tools' in root of joplin folder i.e. D:\GSOC\joplin
- then i executed npm install in the root of joplin folder i.e. D:\GSOC\joplin
This didin't work for me as it showed "This is probably not a problem with npm. There is likely additional logging output above."
So I searched for the solution in stackoverflow (node.js - error: This is probably not a problem with npm. There is likely additional logging output above - Stack Overflow)
I deleted the entire project in my system cloned it again. This time I deleted all the package-lock.json files from the entire project as per the stackoverflow solution and executed npm install. Still it's not working.
The error is as follows:
npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
npm WARN deprecated resolve-url@0.2.1: GitHub - lydell/resolve-url: [DEPRECATED] Like Node.js’ `path.resolve`/`url.resolve` for the browser.
npm WARN deprecated urix@0.1.0: Please see GitHub - lydell/urix: [DEPRECATED] Makes Windows-style paths more unix and URI friendly.
npm WARN deprecated mkdirp-promise@5.0.1: This package is broken and no longer maintained. 'mkdirp' itself supports promises now, please switch to that.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
husky@3.1.0 install D:\GSOC\joplin\node_modules\husky
node husky install
husky > Setting up git hooks
husky > Done
husky@3.1.0 postinstall D:\GSOC\joplin\node_modules\husky
opencollective-postinstall || exit 0
Thank you for using husky!
If you rely on this package, please consider supporting our open collective:
root@ postinstall D:\GSOC\joplin
npm run bootstrap --no-ci && npm run build
root@ bootstrap D:\GSOC\joplin
lerna bootstrap --no-ci
lerna notice cli v3.22.1
lerna info versioning independent
lerna info Bootstrapping 15 packages
lerna info Installing external dependencies
lerna ERR! npm install exited 1 in '@joplin/server'
lerna ERR! npm install stdout:
sqlite3@4.2.0 install D:\GSOC\joplin\packages\server\node_modules\sqlite3
node-pre-gyp install --fallback-to-build
Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
unpack_sqlite_dep
'C:\Users\LSR' is not recognized as an internal or external command,
operable program or batch file.
C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" exited with code 1. [D:\GSOC\joplin\packages\server\node_modules\sqlite3\build\deps\action_before_build.vcxproj]
Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
lerna ERR! npm install stderr:
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in
a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (ReDos Vulnerability Regression Visibility Notice · Issue #797 · debug-js/debug · GitHub)
npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v83-win32-x64.tar.gz
node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.16.0 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! build error
gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "--fallback-to-build" "--module=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd D:\GSOC\joplin\packages\server\node_modules\sqlite3
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\GSOC\joplin\packages\server\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess. (D:\GSOC\joplin\packages\server\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Windows_NT 10.0.18363
node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "D:\GSOC\joplin\packages\server\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd D:\GSOC\joplin\packages\server\node_modules\sqlite3
node-pre-gyp ERR! node -v v14.16.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm WARN rollback Rolling back string-width@2.1.1 failed (this is probably harmless): EPERM: operation not permitted, lstat 'D:\GSOC\joplin\packages\server\node_modules\wide-align\node_modules'
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules\chokidar\node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sqlite3@4.2.0 install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sqlite3@4.2.0 install script.
npm ERR! C:\Users\LSR\AppData\Roaming\npm-cache_logs\2021-03-18T06_59_07_733Z-debug.log
lerna WARN complete Waiting for 7 child processes to exit. CTRL-C to exit immediately.
npm ERR! errno 1
npm ERR! root@ bootstrap: lerna bootstrap --no-ci
npm ERR!
npm ERR! Failed at the root@ bootstrap script.
npm ERR! C:\Users\LSR\AppData\Roaming\npm-cache_logs\2021-03-18T06_59_08_761Z-debug.log
npm ERR! errno 1
npm ERR! root@ postinstall: npm run bootstrap --no-ci && npm run build
npm ERR!
npm ERR! Failed at the root@ postinstall script.
npm ERR! C:\Users\LSR\AppData\Roaming\npm-cache_logs\2021-03-18T06_59_12_170Z-debug.log
Please someone tell me what am I doing wrong.
