First line of "unformatted text" has less indent
Joplin 3.0.15 (prod, linux)
Client ID: 2f52a55e2382439982ec533c0077f388
Keychain Supported: No
Note overview: 1.7.1
Note Tabs: 1.4.0
Search & Replace: 2.2.0
Space Indenter: 0.2.5
Table Formatter Plugin: 1.2.1
Templates: 2.4.0
File system
If I indent text with 4 spaces or with tab for creating "Unformatted text" as described in the guide (Markdown Guide | Joplin), then:
  • IN EDITOR first line of every unformatted paragraph would be with small indentation and rest lines would be with huge indentation.
  • Even if I count spaces one by one, at first line they will have smaller size, but number is same.
  • IN VIEWER all lines aligned straight by left.
If you say it's feature and not a bug, please say also how can I break this unacceptable behavior. Maybe plugin? CSS?
Example (how it looks like, not literally):
  First line of poem
    Just want to preserve all symbols
    Don't want to escape anything
  But first lines
    spoil everything
(I had to type all this text for anew because "NEW USERS MAY ATTACH ONLY ONE PICTURE". And then oops -- nothing.)
In the Android app all are rendered right (just for bump)
