Font settings
I have only 2 options: Default and monospace and idk how to install a custom font
I’m meaning in your phone’s settings. Not Joplin. Haha
I tried there too but still blank.
Btw with very small notes everything is good.
By my phone it’s the same, little notes are working but bigger notes ( i don’t know exactly at which point ) there is like a white text on white Background.
with todays update v329 this Problem seems to be fixed for me.
Yep update fixed for me too
Awesome app awesome devs!
thank you guys for the realy fast fix!
This has been fixed and will be present in the next version.
The mobile version is coming along, folks.
It’s in dire need of some keyboard shortcuts, though. E.g. CMD-F/CTRL-F for find/search (either within a note against all notebooks—or CMD-G, for that matter), CMD-S/CTRL-S to save and/or force a sync, bold/emphasis, italics, maybe CMD-` for code block, CMD-UpArrow/DownArrow for Home/End, maybe a keyboard shortcut to add tags? There’s a lot more here we could really benefit from.
Also, I noticed when in reading mode, the arrow directional keys are non-functional—and in editing mode, the directional keys do move the input cursor, but the screen doesn’t follow if you arrow down past bottom of viewable pane!
Option 1. Here is my biggest wishlist. To be able to move notebooks in iOS versions.
I really really need search note function. I can search in all notes now, but can't search in a note.
