macOS
Joplin 3.3.10 (prod, darwin)
设备:darwin, Apple M4 Pro
客户端 ID: 458391af71e04ac4bd7eba619b92eced
同步版本:3
配置档版本:47
支持的密钥链:是
替代性实例 ID: -
修订:d9ba532
Backup: 1.4.3
Freehand Drawing: 3.0.1
after export pdf .when open the pdf text, there are only some numbers ,have not words. my computer is macbook pro 2024 M4Pro .
KAKALUOTEAAA:
Have you try with different pdf readers and computers to open the same maybe corrupted file ?
Have you use these pdf options ?
I discover something wrong by my side with pdf exportation (3.3.10 too, Kubuntu but not Windows). I can export into pdf one time. After nothing happen (no error messages) : no pdf is created...
Would you be able to share the note you tried to print as a JEX file?
system
Closed
3 June 2025 12:21
5
