Embedded Notes Plugin does not always work
Joplin 3.5.11 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: 0eba133bf40e422fa62146c80df1b9b3
Profile Version: 49
Alternative instance ID: -
Revision: e75875c
AlertsPerfect: 1.0.1
Backup: 1.5.1
Better Code Blocks: 2.0.1
CodePerfect: 1.0.4
Csv Import: 1.0.1
Editor Themes: 1.0.2
Embedded Notes: 1.1.0
Extra Markdown editor settings: 1.11.0
Google Fonts Plugin: 1.0.0
Headings 4 to 6: 1.0.1
Hotstrings & Hotkeys: 1.0.1
Insert Date: 1.0.1
Math Mode: 1.0.0
Note Statistics: 1.0.4
Search & Replace: 2.2.0
Table Formatter Plugin: 1.2.1
Templates: 3.0.0
Text Colorize: 1.2.5
OneDrive
I moved some CSS I've been working with into a separate note and tagged it with "embed". Then I set the tag filter to "embed". When I select that note, it renders the content with the css from the other note about half the time. I have to click away and back, sometimes a couple times, before it renders.
I tested this with several other other snippets and the embedded content does not always load. The only way to get it to load is the select another note in the same notebook and then select that note again. If I select a note in another notebook then back to the note with the embed code it still does not load.
So, apparently, this is a bug in how joplin renders. The plugin is not the issue.
