Elder notes will be automatically updated when first opening in app
Joplin 3.1.24 (prod, win32)
Client ID: f15c90f3f9dc45a5a16d109513f0b22d
Keychain Supported: No
Revision: d581264
File system
When I try to open some old notes (e.g. before 2020), I found these notes got updated automatically, but I did not modify anything.
It indeed shouldn't do this. Do you use any plugin?
No I dont. It's strange but I can provide steps to reproduce:
  1. use latest version of Joplin for Desktop (Windows, portable version), without any plugins enabled
  2. import the attachment by 'ENEX - Evernote Export File (as Markdown)'
  3. open any other note, then open this imported note
  4. update time of this note will be refreshed
exported.enex (665 Bytes)
Thanks, I've created an issue about it here:
