joplin doesn't support pen input. I hope to get this feature, it's useful.
OneNote, Evernote, Google Keep, Notability, Goodnotes, Xournal++, and Squid support pen input and works well with wacom, ipad.
what do you mean. It works perfectly well on desktop and mobile. And it is especially created for pen support, though without pen buttons support unfortunately
The drawing feature was "secretly" released a few days ago!
What platforms? Not seeing on the latest release for iPad
It’s not out yet on iOS. It’ll be in 2.13 What's new in Joplin 2.13
It's released now and will be in the store as soon as Apple approves it
Is there a solution for windows? Using the pen directly in Joplin?
To use handwriting? I think on PC you have to install the plugin manually
correct just install the plugin and you are good to go with the same functionality and same everything
App Store currently shows 12.12.3, what version will have pen support?
On iOS, 12.13.10 should have drawing support. (It should also be available in the AppStore now!)
Hey guys, thanks for the plugin. I've been playing around with it and while it works mostly fine, there is one thing that bugs me: When using the eraser, I want to be able to remove only parts of the lines I've drawn and not the entire line object. This is the standard behavior in other apps such as Xournal++ or RNote. Hope that this is not too big of an issue to implement.
Another thing that I noticed: When I'm drawing and then open settings, all unsaved changes are lost. This is unfortunate since I've lost quite some work. I'd suggest either raising a warning with a promt to save (or discard changes), or some autosave feature.
Also, also (sorry for the spam).
I'm using @CalebJohn's amazing Rich Markdown Plugin. Here, a preview is shown (which is nice), but I don't know how to edit the file. I currently switch to the regular view, then an edit button appears. However, the preview is not updated when changes are saved.
This seems to happen with other plugins that display dialogs.
I've opened a Joplin bug report:
Depending on whether or not the plugin has tried to create a second autosave, this may help: Restoring from an autosave
It's planned :).
Select the ID for the drawing, then click the "draw" button.
See How do I edit drawings from the viewer?
Thanks!
Good to know!
Ah, I remember that I had read it before but could not find it. But I only searched in the forum, I forgot there was already full documentation.
In any case, thanks again for your support and the cool Plugin!
glad to hear that Joplin support pen input, i would have a try with ipad and apple pencil. pctechtest
Hi, is it possible to assign the eraser to a pen button? I know it's possible with other tools such as Rnote but somehow I cannot get it to work with Joplin.
At present, the stylus eraser button should be auto-assigned, but only on some devices and versions of Joplin. In particular,
- On Android, it should work with Joplin >= 3.0.4 (pre-release), but, because the image editor runs in a Chromium-based WebView, it might be broken on Samsung hardware. Also see this GitHub issue.
- On iOS: Untested, should work with Joplin >= 13.0.2 (pre-release).
