Dark mode settings
when i use darkmode, the text is not readable, too dark
can the text set to white?
Did you create notes with a dark font manually, or did you import them from another application like Evernote or Keep?
some are imported from evernote, others from gmail
I asked that question because I experienced the same issue. Notes imported from Evernote are not transferred in a plain format; they are transferred with Markdown codes. Even if you delete those codes, the font continues to stay black. So, my advice is to copy the note with a black font, open a new text, and paste it there as plain text. Then, delete the old note. That's what I did. It's a bit tedious, but unfortunately, there is no other solution.
Thanks a lot.
This issue may be partially fixed in the Joplin 2.14.6 pre-release (see HTML notes: font color incompatible with dark mode · Issue #9511 · laurent22/joplin · GitHub).
Importing from Evernote as Markdown (rather than as HTML) may also fix this issue:
