JBBBB
17 November 2024 22:21
1
macOS
Joplin 3.1.24 (prod, darwin)
The toggle button has been working fine for adding a split screen view of the Markdown editor side-by-side with WYSIWYG.
I typed CMD-L and lost the split screen view. CMD-L now just toggles between Markdown and WYSIWYG - no split screen.
How do I get split screen back?
Try changing the "Layout button sequence" in the "View" menu. This sets the different views that CTRL/CMD+L (and the "Toggle editor layout" button) cycles through.
JBBBB
18 November 2024 15:46
4
Thank you! I knew there must be an easy way to reset this behavior, but was overlooking it.
system
Closed
18 December 2024 17:05
6
