As I understand the notes are stored in .config/joplin/database.sqlite
Why are they still kept there if I Remove them from my CLI application?
The following two settings (from joplin-cli help config) should be relevant here:
revisionService.enabled Enable note history. Type: bool. Default: true revisionService.ttlDays Keep note history for. Type: int. Default: 90
By default, note history is enabled (I'm not sure if there's a way to access previous note versions from CLI...).
Changing the revisionService.ttlDays setting should change how long deleted notes and resources are kept. (For resources, this is even if note history is disabled).
okay, how do I disable note history?
First make a backup of (undeleted) notes:
joplin-cli export --format="jex" ./backup.jex
Next,
joplin-cli config revisionService.ttlDays 1 (delete revisions and unlinked resources after 1 day)
joplin-cli config revisionService.enabled false (disable revisions)should work.
After restarting the app, old revisions (deleted more than a day ago) should be deleted after four or so seconds:
Unlinked resources will be deleted after slightly longer:
Are all these settings saved in .config/joplin? If I want to migrate to another device I just need to backup my .config/joplin dir and move it to .config/joplin on my new device right?
Am I right?
