Checkboxes with three states ala Zim Wiki
A feature I like very much from Zim Wiki is that the checkboxes have four states.
Undone / Done / Wont do / Moved. See: https://zim-wiki.org/manual/Help/Check_Boxes.html
Sometimes just two states for a task “Checked / unchecked” is a bit lacking in the information it gives. Adding the other two states gives a more powerful use of the checkboxes.
Would this be possible to implement in Joplin?
I would like this feature too! But with four states: empty ( ), completed (v), discarded (x), under question (.)
Similar thread: More checkbox types - #2 by nr458h
Somebody might be able to make a plugin for it but there isn't a Markdown spec for it so it wouldn't be portable if that is what was required.
I like this idea too. Personally I would love that clicking on a checkbox would cycle between three states: not started (unchecked), partially completed (in progress) and completed (checked).
[ ] => [-] => [x]
Related:
