Capitalize the first letter
Hi to everyone.
I’m using Linux Manjaro KDE.
My version of joplin is 1.0.193
I notice this issue every time I wanna write something.
It’s just simply too annoying to hold shift before writing something at the beginning of the sentence. Especially when I’m writing on Joplin.
Thanks all in advance:)
I’ve put these rules in my ‘userstyle.css’ file
h1::first-letter,h2::first-letter,h3::first-letter,h4::first-letter {
 text-transform: uppercase;
p::first-letter {text-transform: uppercase;}
See also the topic on CSS sharing
Thank you so much
Just a problem
Where it userstyle.css in linux?
Update : I found it on preferences
Thank you so so much :slight_smile:
Just one problem
How can i use this for lists?
For example the first letter after “-” should be capital? like this:
  • Hello
  • World.
Or this:
1- Hello
2- World
I made it right by changing the userstyle.css to:
*::first-letter {text-transform: uppercase;}
I’ve limited this to list only, with
ul::first-letter,ol::first-letter,li::first-letter {text-transform: uppercase;}
Correct me if I’m wrong, but isn’t just li::first-letter {text-transform: uppercase} suffecient? (since ul and ol are just containers and the text will only be in list items)
You're right. My CSS knowledge is low…
Hi
Not completely.
You can put numbers, images, etc in lists
But what about when you’re writing your headings?
No i’m just like you
Thank you so much:)
Ah, makes sense. But you would have to use raw html for something like that, no? As far as I know markdown lists are only containers for list items.
Not quite like that
Look lists are just “lists” not containers
You can put ANYTHING in them;)
What I meant was, any text you put in a list would be in the list item, not directly in the list right? So styling the list item should have been sufficient.
Yes you’re right but my question was different
I wanted a solution to capitalize every first letter. Not just in lists:)
I got that. I was speaking about lists specifically :grinning:
What you have works good
Lol yeah
Oh thank you man:)
I have a big problem now
How can i make all the elements first letter capitalized but code
I mean when we’re writing a code like:
this is a code
we don’t want its first letter to be capitalized
@darklight-oss
I think it’s because of the general capitalizing by
For this, I prefer targeted rules on objects I want to capitalize, as p, li, h#, etc.
Thanks for replying
Yeah i’m aware of it
I wanted to know if someone knows how to exclude code sections from others?
