Can "Note properties" be added to the menu system?
I use a very minimal interface in Joplin, having hidden most of the button. This has caused me to notice that the Note properties is not found in the app menu system. I would have expected to find it below or above Note > Statistics…
Without that the only way to access it (without the button) is to use the command pallet.
Could this be added to the menu system?
It is available right in the note window (on the right side in standard layout). Click on the little circle with an i in the center.
Sorry I didn't explain well enough. I have hidden all the tool bars. I don't do much formatting and I'm on a smaller device. So I don't have that icon to click on.
Also for keyboard users, it makes sense to have in in the menu system.
That's true, it should appear in the menu too. Would you mind creating an issue about it in GitHub?
My pleasure!
Not much to it, though.
Thanks!!!
Latest version has the feature working well. Thanks!
@moderators could close this thread if you like.
