Bug report: note not syncing
Joplin 3.2.11 (prod, win32)
Client ID: 535a556699144fa590a7d99171622c2e
Keychain Supported: No
Revision: 2fba101
Freehand Drawing: 2.14.0
OneDrive
I edited 1 note on an Android device, and synced
Now, looking on Windows, the note is empty - no text, no attachments. Synched several times - no effect
I replicated the problem:
  1. Create note on desktop; sync
  2. go to android; sync; add attachment to the new note, sync
  3. Back to the desktop, sync -> this the attached picture with no way out of it. Can't see text either.
With this set to Manual -> I get this problem.
It's a bug, it should not affect text being downloded, only the attachment. As it is, there's nothing to click on because the text and icon is not there
I could reproduce the behaviour using provided steps,
Thanks for reporting
I wanna add few details
Details
Ubuntu 24.04
Android 13
3.2.11 desktop
3.2.7 mobile
Joplin 3.2.11 (prod, linux)
Client ID: 169b6340643343e29989371d139b9ebe
Revision: 2fba101
Backup: 1.4.2
CodeMirror 6 snippets: 0.0.8
Extra Markdown editor settings: 1.9.0
Joplin Batch: 0.2.2
Note Link System: 0.8.0
Note list (Preview): 1.1.0
Quick Links: 1.3.2
Rich Markdown: 0.15.1
Dropbox
Manual download mode doesn't download attachments on desktop CodeMirror editor when clicked on and locks up RTE from editing the note body
Notes
  • Error message (Please wait for all attachments to be downloaded and decrypted. You may also switch to Code View to edit the note. Status: notDownloaded) shown only in RTE (TinyMCE) editor
  • When this error message is displayed, RTE editor locks up -- does not allow any editing of note body. Note title remains to be editable
  • When this error message is displayed toolbar becomes inactive (greyed out) restricting ability to switch editor back to Markdown one (CodeMirror) - despite what error message says
Codemirror
  • It's possible to switch from RTE editor by going to non-locked note, switching to CodeMirror and going back to the locked note
  • Alternatively user can switch editor to CodeMirror with Command Pallete ToggleEditors
  • Markdown editor shows link to the attachment as expected, clicking on the link displays the warning
What's expected
RTE
  • Display link to non downloaded attachment in RTE editor
  • Do not lock up RTE editor with error message i.e. allow edits and use of toolbar even if attachment is not downloaded
  • Display error in a way that doesn't lock up RTE editor from edits (pop-up, toast, etc)
  • Error message to display "This attachment is not downloaded yet"
  • Ask user to wait for download completion only if attachment downloading has started
Codemirror
  • In Manual Attachment download mode, start downloading attachment when user (ctrl+)clicks on attachment link
Extra
  • Display status of downloading for attachments (completed/in process/non downloaded)
Logs
Opening note in RTE with non-downloaded attachment produces following logs:
useMessageHandler.ts:31 Got ipc-message: noteRenderComplete null
Opening the note in CodeMirror and opening the attachment produces no log entries
