BUG ? - Incorrect copy/paste of images from a note to another (or to the same note)
Joplin 3.3.9 (prod, linux)
Device: linux, x64
Client ID: 44e3fdd0cdfd4c84b028b4fac399f990
Keychain Supported: No
Alternative instance ID: -
Revision: 5d0fa75
Backup: 1.4.3
Freehand Drawing: 3.0.1
Record: 1.5.0
Rich Text Editor
Before reporting to GITHUB...
Warning : not the know copy image issue from another app and JOPLIN. Here it's between two JOPLIN notes or inside the same note.
Issue number one
There's not "cut" in the right click on an image:
Issue number two
If I select all images ( [CTRL A] ) and apply a "copy", only one image (the image where I did the right click) will be really copied and pasted !
Issue number three
Impossible to select multiple images with the mouse and [CTRL] (one image to one image) or with [MAJ] (image of the start of the selection to the image of the end of the selection).
Issue number four
However it's possible to do a multiple selection with the mouse and drawing a rectangular selection. BUT... it's impossible to select the first image...
Is it the same for you ?
Possibly a limitation of the Rich text editor. If you switch to the mark down editor I suspect you will be able to copy the whole note contents to another note
Yes. Absolutely.
Still have it with 3.3.12.
Next step: GITHUB
