Attachments that could not be downloaded - Resource not found
macOS
Joplin for Desktop
Copyright © 2016-2024 Laurent Cozic
Joplin 3.0.14 (prod, darwin)
Client ID: 77086ccf862f4a3fbabc6497a8a3ab89
Revision: 05cf51e
Admonition markdown extension: 1.1.0
Backup: 1.4.1
Better Code Blocks: 1.1.0
Cursor Sync: 2.1.0
Paste Special: 1.1.2
Quick Links: 1.3.0
File system
Rich Text Editor
Howdy folks,
I seem to have a sync error I cant resolve, I'm getting the following: -
Not downloaded: 0
Downloading: 0
Downloaded and decrypted: 5225
Downloaded and encrypted: 0
Created locally: 0
Error: 1
Retry All
3fb4caaba82f54c867e07d7bc3c65a67 (1a24b1df48ef4653a8b161937a374f26): Resource not found: 1a24b1df48ef4653a8b161937a374f26 Retry
Retry All
Sync status (synced items / total items)
Note: 860/860
Folder: 154/154
Resource: 5205/5205
Tag: 152/152
NoteTag: 1212/1212
Revision: 2/2
Total: 7585/7585
Conflicted: 0
To delete: 0
I have the 1a24b1df48ef4653a8b161937a374f26.md file in the folder holding all my Joplin notes and I get the same error if I bin it off and re-sync. I've also tried the 'Delete local data and re-download from sync target' option and its the same :confused:
Any ideas on how I can bin this out of the app? I'm unsure which note/book it relates and and isnt the end of my world if its lost...just want to remove the sync error!
thanks
Doug
If you're just interested in removing the sync error, deleting the resource may help. To do this,
  1. Make sure you have a recent backup of your notes.
  2. Copy the resource ID (1a24b1df48ef4653a8b1619374f26).
  3. From the main Joplin screen, open Tools > Note Attachments.
  4. Search for the resource ID.
  5. Click "Delete".
That sorted it, many thanks! I wasn't aware of the 'Note Attachments' section in the menu's!
Thanks again :slightly_smiling_face:
