Android keeps on "resetting" my sync and theme
  • Version: 1.1.2, Android
  • Webdav sync
  • Encryption on
I have an issue on Android. I have done the setup for sync, encryption and changed theme. However, it keeps on reseting and removing these settings for me. It doesn't happen instantly but first after the app has had the setting for about 2-3 hours. Then when I open the app it says "Initialse app" and then my notes are still there, but the sync setting is gone (it has changed back to the default "Dropbox"), I'm back on the white theme and I get the yellow-bar that let's me know I need to add my encryption key.
Has anyone else seen a similar issue and know how I can solve it?
Thanks
this might be the same error as described here:
