Hi Laurent!
Uninstalled. Reinstalled 1.0.181. No notes, no syn, starting leads to white screen again.
Console log from Android:
[ 12-20 21:53:11.328 11033:11063 I/ReactNativeJS ]
OPEN database: joplin.sqlite
[ 12-20 21:53:11.378 11033:11069 E/SQLiteLog ]
(1) statement aborts at 39: [CREATE VIRTUAL TABLE notes_fts USING fts4(content=“notes”, notindexed=“id”, id, title, body)] unrecognized parameter: notindexed=“id”
[ 12-20 21:53:11.378 11033:11069 E/SQLiteQuery ]
exception: unrecognized parameter: notindexed=“id” (code 1); query: CREATE VIRTUAL TABLE notes_fts USING fts4(content=“notes”, notindexed=“id”, id, title, body)
[ 12-20 21:53:11.388 11033:11069 E/unknown:SQLitePlugin ]
SQLitePlugin.executeSqlBatch: failed
android.database.sqlite.SQLiteException: unrecognized parameter: notindexed=“id” (code 1)
at android.database.sqlite.SQLiteConnection.nativeExecuteForCursorWindow(Native Method)
at android.database.sqlite.SQLiteConnection.executeForCursorWindow(SQLiteConnection.java:1035)
at android.database.sqlite.SQLiteSession.executeForCursorWindow(SQLiteSession.java:836)
at android.database.sqlite.SQLiteQuery.fillWindow(SQLiteQuery.java:62)
at android.database.sqlite.SQLiteCursor.fillWindow(SQLiteCursor.java:144)
at android.database.sqlite.SQLiteCursor.getCount(SQLiteCursor.java:133)
at android.database.AbstractCursor.moveToPosition(AbstractCursor.java:197)
at android.database.AbstractCursor.moveToFirst(AbstractCursor.java:237)
at org.pgsqlite.SQLitePlugin.executeSqlStatementQuery(SQLitePlugin.java:822)
at org.pgsqlite.SQLitePlugin.executeSqlBatch(SQLitePlugin.java:724)
at org.pgsqlite.SQLitePlugin.access$100(SQLitePlugin.java:49)
at org.pgsqlite.SQLitePlugin$DBRunner.run(SQLitePlugin.java:936)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
at java.lang.Thread.run(Thread.java:841)
[ 12-20 21:53:11.388 11033:11063 I/ReactNativeJS ]
warning - exception while invoking a callback: {“code”:0,“line”:1039,“column”:8354,“sourceURL”:“index.android.bundle”}
Thank you!
