Android conflicts
Android
OneDrive
Dear Users, I edit and sync between three devices, 2 PCs and 1 Android Phone. I use One Drive as a storage. Unfortunately some notes appear (on the android device) under the conflicts folders and the same aren't visualized on the windows app, which doesn't show neither the conflicts folder nor the notes.
any ideas on how to solve? any help would be much appreciated
Hello and welcome to the forum,
It might be similar to this issue
https://joplinapp.org/help/faq#not-all-notes-folders-or-tags-are-displayed-on-the-mobile-app
Try reinstalling the app and keep the app foreground during first sync
Hope this helps,
thanks I'll take a look
for some reason forum editor trimmed the correct section, I updated the link to make it more precise
