Hi, i using Joplin on Linux, Windows, iOS and Android.
because of Issues with encrypted notes i decided to deaktivat encryption. Now, after a while of usage Joplin i have encrypted and unencrypted Data in the Database.
The Android App is not longer decrypting Notes and i cant export to an jex-File, because my Linux-Desktop-App tells, there are undecrypted Files.
How can i clean up this mess?
I have still the encryption-keys in desktop app, i also have passwords, but decryption is not working.
I believe this is possible to fix by having all encryption keys on your main desktop PC, export everything as RAW, delete all apps and data everywhere and setup again without encryption starting with importing RAW folder in your main PC.
As I understood RAW export does not contain encrypted data. As well as any other export, but I believe the RAW export would be better for cleaning errors.
