Adding hyperlink, focus on wrong field
macOS
Device: darwin, Apple M2
Client ID: 592616c5e37c4cf392a05d790feb3bb7
Profile Version: 49
Alternative instance ID: -
Revision: 0c1511f
Backup: 1.5.1
Copy Code Blocks: 2.1.0
Extra Markdown editor settings: 1.11.0
Joplin Batch: 0.2.2
macOS theme: 1.5.20
Outline: 1.5.15
Templates: 3.0.0
YesYouKan: 1.1.3
Rich Text Editor
To add a hyperlink, select text and press CMD-K.
So far so good.
But now the cursor (focus) is on the "Text to display" field.
Why? Didn't I just select the text?
The focus should be on the URL field
People expect the focus to be on the URL field, that is how every other application/editor works.
BTW, the URL field should be wider, at least the size of the "Text to display" because it will always be bigger)
Has anyone else noticed this problem?
