Zooming on images?
Hello
I have editor width of 600, which is very comfortable, but in some of my notes I usually insert screenshots from presentations and the image appears too small for me to read (even when enlarged to the full 600 wifth). Is there a way to click on image and expand it temporarly and maybe browse trough images in the same note? Like it happens with Notion.
Thanks
If you right click an image > open (if in the markdown editor ctrl + click on the image embed text will also work) it should open the image in your default image viewer where you could zoom it
Thanks but assume i have 20 images in a note and i want to browse trough them like in notion? using external app is not convenient
I don't think there's any way to do that currently, but it would most likely be possible with a plugin (though I don't think any such plugin exists currently)
Hi, @ironhak
I may have a solution for you. Here are my notes.
I'm using encrypted notes in Joplin so that I can't do what you purposed
