Whiteboard enhancements
I have been enjoying the Whiteboard feature so far. I get that since it is fairly new it still has a ton of room for improvements. These are some of the things I would like to see in the whiteboard, if they are possible.
  • Export rendered whiteboard to PDF (instead of JSON)
  • Better math rendering in cards (for now math rendering is werid with a mix of rendered Markdown and raw text)
  • Move/copy cards/groups between whiteboards (also multiple cards and groups in one go, kind of importing a whiteboard into another)
    • Converting a card into a note allows for this, but there might be situations where one might wish not to create new notes
  • Add a grid for organization, with possible grid snapping (don't know if this is supported by jsoncanvas)
  • Edit arrow curves (change shape/curvature with mouse drag)
  • Infinite zoom in/out
  • Keyboard shortcuts (e.g. Ctrl+A to select all objects on the canvas)
  • Visual indicator of tag in card (like for the YesYouKan! Kanban plugin)
Feel free to add your own, I will try to update the list with any comments
