Hi !
I'm trying to add a simple asciimath (http://asciimath.org/) implementation to Joplin. I proceeded by first duplicating the katex.js rule and adding my new file (asciimath.js) in MdToHtml.js.
Asciimath blocks works like a charm but inline math seems to be ignored, and i can't find where i broke it...
Here is the diff (katex.js/asciimath.js)
9a10
> const AsciiMathParser = require('./asciimath2tex.js')
10a12
> const asciiparser = new AsciiMathParser();
48c50
< // Assumes that there is a "$" at state.src[pos]
> // Assumes that there is a "£" at state.src[pos]
74c76
< function math_inline(state, silent) {
> function asciimath_inline(state, silent) {
77c79
< if (state.src[state.pos] !== '$') {
> if (state.src[state.pos] !== '£') {
84c86
< state.pending += '$';
> state.pending += '£';
96,97c98,99
< while ((match = state.src.indexOf('$', match)) !== -1) {
< // Found potential $, look for escapes, pos will point to
> while ((match = state.src.indexOf('£', match)) !== -1) {
> // Found potential £, look for escapes, pos will point to
111c113
< // No closing delimter found. Consume $ and continue.
> // No closing delimter found. Consume £ and continue.
114c116
120c122
< // Check if we have empty content, ie: $$. Do not parse.
> // Check if we have empty content, ie: ùù. Do not parse.
123c125
< state.pending += '$$';
> state.pending += '££';
133c135
140,141c142,143
< token = state.push('math_inline', 'math', 0);
< token.markup = '$';
> token = state.push('asciimath_inline', 'math', 0);
> token.markup = '£';
149c151
< function math_block(state, start, end, silent) {
> function asciimath_block(state, start, end, silent) {
162c164
< if (state.src.slice(pos, pos + 2) !== '$$') {
> if (state.src.slice(pos, pos + 2) !== '££') {
172c174
< if (firstLine.trim().slice(-2) === '$$') {
> if (firstLine.trim().slice(-2) === '££') {
197c199
< .slice(-2) === '$$'
> .slice(-2) === '££'
199c201
< lastPos = state.src.slice(0, max).lastIndexOf('$$');
> lastPos = state.src.slice(0, max).lastIndexOf('££');
207c209
< token = state.push('math_block', 'math', 0);
> token = state.push('asciimath_block', 'math', 0);
211c213
< token.markup = '$$';
> token.markup = '££';
253a256
> latex = asciiparser.parse(latex);
255c258
< return `<span class="joplin-editable"><span class="joplin-source" data-joplin-language="katex" data-joplin-source-open="$" data-joplin-source-close="$">${md.utils.escapeHtml(latex)}</span>${renderToStringWithCache(latex, options)}</span>`;
> return `<span class="joplin-editable"><span class="joplin-source" data-joplin-language="katex" data-joplin-source-open="£" data-joplin-source-close="£">${md.utils.escapeHtml(latex)}</span>${renderToStringWithCache(latex, options)}</span>`;
262c265
< const inlineRenderer = function(tokens, idx) {
> const asciimathInlineRenderer = function(tokens, idx) {
268a272
270c274
< return `<div class="joplin-editable"><pre class="joplin-source" data-joplin-language="katex" data-joplin-source-open="$$ " data-joplin-source-close=" $$ ">${md.utils.escapeHtml(latex)}</pre>${renderToStringWithCache(latex, options)}</div>`;
> return `<div class="joplin-editable"><pre class="joplin-source" data-joplin-language="katex" data-joplin-source-open="££ " data-joplin-source-close=" ££ ">${md.utils.escapeHtml(latex)}</pre>${renderToStringWithCache(latex, options)}</div>`;
277c281
< const blockRenderer = function(tokens, idx) {
> const asciimathBlockRenderer = function(tokens, idx) {
282,283c286,287
< md.inline.ruler.after('escape', 'math_inline', math_inline);
< md.block.ruler.after('blockquote', 'math_block', math_block, {
> md.inline.ruler.after('escape', 'asciimath_inline', asciimath_inline);
> md.block.ruler.after('blockquote', 'asciimath_block', asciimath_block, {
286,287c290,291
< md.renderer.rules.math_inline = inlineRenderer;
< md.renderer.rules.math_block = blockRenderer;
> md.renderer.rules.asciimath_inline = asciimathInlineRenderer;
> md.renderer.rules.asciimath_block = asciimathBlockRenderer;
If you're up to help me and you need more informations i'll be glad to provide it ![]()
