Would it be possible to add an option for the Web Clipper extension to clip an URL into an existing note?
Currently, the Web Clipper saves each URL as a new note, using page title as the note title and the URL as the note body. While there may be scenarios in which they are desirable, I find this fairly clunky when the number of clippings grows.
My personal case scenario is Joplin as a RIL app, there's a RIL notebook, and each category corresponds to a different note. This keeps note proliferation under check.
Clipping the URL to an existing note would result in a line being added, e.g.:
- [#page_title#](#page_URL)
There was a previous suggestion that is similar, but mine is more specific and I believe pretty easy to implement.
