Warning about variable NODE_TLS_REJECT_UNAUTHORIZED set to zero
When, i run joplin-desktop version 2.2.7 I get the following message:
"(node:68265) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification"
Should I do something?
I use joplin-desktop with joplincloud.
We set this variable when the setting "Ignore TLS certificate errors" is on, so you might want to check this. The message is correct, but it's a user's choice.
