Hi all,
I'm using Joplin 2.9.17 on Windows 10.
I can't install plugins because I have a corporate MITM firewall intercepting TLS traffic, reading my emails, hacking my code, etc.
The plugins tab shows this error, which makes sense (electron app -> openssl -> MITM ssl cert -> validation error, I assume):
Could not connect to plugin repository.
Is there a way to add my corporate CA cert specifically for plugins? Or even better, to simply ignore TLS cert errors for plugins?
I see in Synchronization, we have both... "Custom TLS Certificates", and also "Ignore TLS Certificate errors". I'd love to have similar settings for plugins.
I don't care at all about the integrity/security/privacy of joplin plugins specifically related to my corporate firewall. And I would love to be able to install plugins using this tab. I can install some plugins by downloading the JPL files, but it looks like not all plugins provide ready-made JPL files (e.g. I wanted to install joplin-template plugin, and hit this roadblock yet again).
If there's no current way to do this, I'll open a github issue for it.
Thanks!
