(Tools->) Note Attachments - Improvement suggestion
I moved over from Evernote some time ago - and very happy to have done so! - which I had been using with web clippers for many years. My experience is they don't always work exactly as intended in particular regarding importing images, and I'm sure that has contributed significantly to the massive size of my sync database at just under 3GB
So I'd like to trim that down, but the Joplin View Attachments tool is presently not fit for purpose to make any sort of a dent in this! I'd like to propose the following changes to make it significantly more useful:
1. Make the hyperlink in the title column right clickable with an option "open in new window"
2. Introduce a new clickable column to select multiple attachments
3. A global trash can button where attachments selected in 2) can all be deleted (the refresh of the whole attachment view back to the beginning following a single delete is currently the biggest problem imv right now)
Many thanks for your consideration!
Edit: one other thing occurs to me. It would also be helpful to add:
4 Note title/notebook the particular attachment belonged to!
Many thanks
