/home/user/.local/bin/run-joplin.sh
#!/bin/sh
firejail \
--appimage \
--noprofile \
--env=XDG_SESSION_TYPE=wayland \
--env=WAYLAND_DISPLAY="$WAYLAND_DISPLAY" \
--whitelist="$HOME/Downloads" \
--read-only="$HOME/Downloads" \
--whitelist="$HOME/Pictures" \
--read-only="$HOME/Pictures" \
--whitelist="$HOME/.local/share/icons" \
--read-only="$HOME/.local/share/icons" \
--whitelist="$HOME/.local/share/fonts" \
--read-only="$HOME/.local/share/fonts" \
--whitelist="$HOME/.config/fontconfig" \
--read-only="$HOME/.config/fontconfig" \
--whitelist="$HOME/Dropbox/app/Joplin" \
--whitelist="$HOME/.config/Joplin" \
--whitelist="$HOME/.config/joplin-desktop" \
--whitelist="$HOME/Your-Joplin-Backup-Folder" \
--whitelist="$HOME/Applications/Joplin.AppImage" \
--no-sandbox \
--enable-features=UseOzonePlatform \
--ozone-platform=wayland \
/home/user/.local/share/applications/appimagekit-joplin.desktop
TryExec=/home/user/.local/bin/run-joplin.sh
Exec=/home/user/.local/bin/run-joplin.sh %u
Joplin does not appear to use the ~/.cache directory.
The --no-sandbox option is required because it disables Joplin's built-in Chromium/Electron sandbox, allowing Firejail to handle sandboxing instead.
If you want to block all network access, simply add the --net=none \ option.
Try exporting to PDF or JEX — you'll see that the Firejail sandboxing is doing a fantastic job.
