Syncronization error: "Error Missing required property: type_"
The version you are using. LATEST VERSION is not a version number
Joplin 1.7.11 (prod, linux)
Client ID: e21a6520e2db45b3970aac4d97d95420
Sync Version: 2
Profile Version: 34
Keychain Supported: No
Revision: f560563 (master)
If it is a sync issue, please let us know what you are syncing with.
I am syncing with a file system
The operating system you are using
Ubuntu 18.04.5 LTS
Unfortunately, I can't provide a log as there is no Toggle Developer Tools in View section of the menu
As I understand, the error happens with one specific note. I see the following error report in the bottom left corner of Joplin:
Completed: 27/08/2021 09:53
Last error: Error: Missing required property:
type_:
Export debug report
I tried to solve the sync problem by cutting this note, syncing, and pasting the note again. It didn't help. I add Export debug report too:
Not downloaded: 0
Downloading: 0
Downloaded and decrypted: 0
Downloaded and encrypted: 0
Created locally: 33
Error: 0
Sync status (synced items / total items)
Note: 304/304
Folder: 14/15
Resource: 33/33
Tag: 219/231
NoteTag: 535/567
MasterKey: 0/0
Revision: 294/241
Total: 1399/1391
Conflicted: 0
To delete: 2
I will really appreciate your help
This usually happens, when you manually edit files on the sync target. I bet that one note has an EOL at EOF.
The log file should tell you which note it is.
option 1: Export that note as JEX. Delete the note. Import the JEX.
option 2: Strip the last byte of the file on the sync target
P.S.: You can also search this forum for "error missing required" (without the quotes).
