Synchronize error message needs a solution
Joplin 2.13.15 (prod, win32)
Client ID: ee08f83bca194542b17b4edec9a13f6b
Profile Version: 44
Revision: 7d2c1c0
Nextcloud
Fetched items: 1/8.
Completed: 25/01/2024 09:05 (12s)
Last error: Error: On file 0be6c0ddf4e40e2a629933d61f424bbc.md: Missing required property: type_: Ohio Driver License (1).jpg id: 0be6c0ddf4e40e2a629933d61f424bbc mime: image/jpeg filename: Ohio Driver License (1).jpg created_time: 2024-01-21T20:44:00.058Z updated_time: 2024-01-21T20:44:00.058Z user_created_time: 2024-01-21T20:44:00.058Z user_updated_time: 2024-01-21T20:44:00.058Z file_extension: jpg encryption_cipher_text: encryption_applied: 0 encryption_blob_encrypted: 0 size: 216052 is_shared: 0 share_
Looks like this file "0be6c0ddf4e40e2a629933d61f424bbc.md" is corrupted so you might have to restore it from backup or manually fix it
Hi, thanks for responding. I did think just remove the note and see what happens. It resulted in a different file being referenced and couched in the same error message.
I recently downloaded Joplin and move selected notes and a notebook from evernote as I am looking for an evernote replacement.
Should I just uninstall Joplin and start over?
The app is probably fine but it seems the data on the sync target is corrupted. Did you manually change files over there?
Thank you for your help. I am in the get-to-know-Joplin phase so I am exporting just a few sample EverNote notes and notebooks. I erased all the files from Joplin and NextCloud, did a shutdown, and started my laptop.
Next, I exported and imported a few sample EverNote notes and notebooks. This time, no error messages!! :smiley:
