I’ve setup a dual boot system with Windows 10 and Ubuntu 20.04 and installed Joplin 1.0.227 on both OS. I use a NTFS formatted partition as synchronization target for both systems. If I start Joplin and set the synchronization target in Ubuntu it loads the notebooks and notes that I’ve created with Windows. But every change I made from this point won’t show up in one of the other systems. Instead I get conflicts when I synchronize changes.
I’m fairly new to Linux so this might be a configuration fault on my side but changes are saved to the files they seems just to be ignored when I synchronize. I wonder if I even have to synchronize after Joplin starts.
Edit: Windows just loaded changes I made in Ubuntu, but Ubuntu refuses to load changes or new notebooks from Windows
