This is the error I get:
Created local items: 1
Fetched items:8000/8000
Completed: 17/06/2018 02:38
Last error: Error: POST files/download: fetchBlob error (409)
{“error_summary”:“path/restricted_content/.”,“error”:{".tag":“path”,“path”:
{".tag":“restricted_content”}}}
I am getting this error from syncing with dropbox
Does it do it again when you click the Synchronise button again?
Yes it happened 4 times in a row same message.
This apparently means that the file that’s being uploaded has been restricted due for example to DMCA, malware, etc. but it can also be a false positive. https://www.dropboxforum.com/t5/API-Support-Feedback/409-path-restricted-content-on-shared-folder/td-p/271411
I will add an exception so that this type of file is skipped during sync.
Ok thanks I will try and figure out which file it might be.
Just my 2 cents: encryption should help in this situation as well.
